[Qgis-developer] SAGA Processing toolbox geoalgorithm not working on Ubuntu 14.04
roy
royroge at outlook.com
Wed Jan 21 11:12:58 PST 2015
Dear list,
i'm trying to use SAGA natural neighbour via QGIS toolbox but it's not
working,
the tool opens the config dialog but when i run it i get
this errors:
Oooops! The following output layers could not be open
* Grid: /tmp/processing/c62751a9186c4e0694e956b2bf65fda0/USERGRID.tif
The above files could not be opened, which probably indicates that they
were not correctly produced by the executed algorithm
Checking the log information might help you see why those layers were
not created as expected
This algorithm requires SAGA to be run. A test to check if SAGA is
correctly installed and configured in your system has been performed,
with the following result:
SAGA seems to be correctly installed and configured
and on "OGR" QGIS log:
error 4: Unable to open
/usr/share/qgis/python/plugins/processing/tests/data/polygons.shp or
/usr/share/qgis/python/plugins/processing/tests/data/polygons.SHP.
2015-01-21T19:58:47 1 Data source is invalid ()
2015-01-21T20:08:20 1 Data source is invalid ()
are SAGA tools supposed to work or is there some known problem?
P.S. the very same tool works on windows with osgeo4w install
Thanks, Roy.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150121/d68d6fe2/attachment-0001.html>
