[Qgis-developer] Problem when using spatial index
Nejia Ben Nasr nejia.bennasr at spaceyes3d.com
Thu Jan 22 00:37:14 PST 2015
Thank you very much delazj.
Nejia
De : Junior [mailto:delazj at gmail.com]
Envoyé : jeudi 22 janvier 2015 09:19
À : Nejia Ben Nasr
Cc : qgis-developer at lists.osgeo.org
Objet : Re : [Qgis-developer] Problem when using spatial index
Then fix the layer with duplicate nodes. As stated here [1], it can be done with the tool in vector menu > Geometry tools > Simplify geometry (setting the tolerance to 0)
[1] http://docs.qgis.org/2.2/en/docs/user_manual/plugins/plugins_ftools.html
Envoyé depuis mon HTC
----- Reply message -----
De : "Nejia Ben Nasr" < <mailto:nejia.bennasr at spaceyes3d.com> nejia.bennasr at spaceyes3d.com>
Pour : "'Junior Delaz'" < <mailto:delazj at gmail.com> delazj at gmail.com>
Objet : [Qgis-developer] Problem when using spatial index
Date : mer., janv. 21, 2015 16:11
To inderstant the source of problem, if it’s caused by invalid geometry I do this:
-          I load only a shapefile containing geometry with duplicate nodes and I remove file .qix, here the problem appear: the spatial index is atomically created and I can’t see all feature when I zoom or navigate in the map.
-          I have another shapefile containing some rows without geometry, I load only it in Qgis and I create a spatial index, here there is no problem
De : Junior Delaz [ <mailto:delazj at gmail.com> mailto:delazj at gmail.com]
Envoyé : mercredi 21 janvier 2015 14:57
À : Nejia Ben Nasr
Objet : Re: [Qgis-developer] Problem when using spatial index
I assume duplicate nodes invalidate geometry but I don't think such thing can create the current bug. OGR/GEOS guru?
But if I understand your second sentence, you have a shapefile containing some rows without geometry. Right? So, what do u mean by "I don't have a problem with this file"? Is it another file or the file on which you're creating the spatial index?
You should :
- open a new project and add only the problematic file
- or delete from your current project the file with empty geometry (if it's not the one you're creating spatial index on)
to see how it reacts when zooming in/out ...
2015-01-21 14:26 GMT+01:00 Nejia Ben Nasr <nejia.bennasr at spaceyes3d.com>:
The  problem appears with vector layers that contain geometries that containing duplicate node(s), it’s considered as an invalid geometry ?
When I select all features from the bounding box of the vector layer, lines of features that has a null geometry are not selected in the attribute table (I don’t have a problem with this shapefile).
Thanks,
Nejia
Envoyé : mercredi 21 janvier 2015 13:47
À : Nejia Ben Nasr
Cc : 'qgis-developer'
weird, it worked for others.
And if you spatially select all your features, are all the lines in the attribute table being selected?
You haven't answered about checking geometry validity...
De : "Nejia Ben Nasr" <nejia.bennasr at spaceyes3d.com>
Pour : "'Junior'" <delazj at gmail.com>
Cc : "'qgis-developer'" <qgis-developer at lists.osgeo.org>
Date : mer., janv. 21, 2015 13:30
Yes, even if I delete the .qix before saving !!
Thanks,
Nejia
Envoyé : mercredi 21 janvier 2015 13:23
À : Nejia Ben Nasr
And if you delete the .qix before saving? And then recreate it...
Pour : "'Junior Delaz'" <delazj at gmail.com>
Date : mer., janv. 21, 2015 13:14
I already tried to save to anther shapefile and edit it (add, modify, remove features …) the .qix was automatically created and I get the same problem
Thanks,
Nejia
De : Junior Delaz [mailto:delazj at gmail.com]
Envoyé : mercredi 21 janvier 2015 12:21
À : Nejia Ben Nasr
Cc : qgis-developer
Some users [1] have already encountered this issue and i understood that it may be related to non correspondance between the number of rows in the .dbf file and number of geometry (some rows had no geometry). A simple "Save As.." to another shapefile has solved the problem.
[1] http://georezo.net/forum/viewtopic.php?id=95143 (in french, sorry )
2015-01-21 9:16 GMT+01:00 Nejia Ben Nasr <nejia.bennasr at spaceyes3d.com>:
Do you think that this problem is often caused by geometry problems?
Thanks,
Nejia
Envoyé : mardi 20 janvier 2015 13:41
À : Nejia Ben Nasr; 'qgis-developer'
Nejia, what about the validity of the geometry of your features? You can check with the tool in Vector menu > Geometry tools > check geometry validity
Pour : "'qgis-developer'" < <mailto:qgis-developer at lists.osgeo.org> qgis-developer at lists.osgeo.org>
Date : mar., janv. 20, 2015 13:03
I use QGIS 2.6.1
De : qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-bounces at lists.osgeo.org] De la part de Nejia Ben Nasr
Envoyé : mardi 20 janvier 2015 09:39
À : qgis-developer
Hi all,
I load a shapefile, then I create a spatial index to maximize speed of zoom and navigate in the map.
The problem is: when I zoom to any area feature appear and other doesn’t.
And it seems To me that the spatial index is automatically created even when I delete the .qix file
Best regards,
Nejia
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150122/4da2ac67/attachment-0001.html>
