[Qgis-developer] Processing : 2 Pull Requests for merging before feature freeze
Arnaud Morvan
arnaud.morvan at camptocamp.com
Fri Jan 23 03:18:24 PST 2015
For a short description:
With the new parameter type for geometry predicates, the user can choose
precisely the spatial relation to use in these algorithms :
Select by location
Extract by location
Join attributes by location
With the new fields mapper algorithm, you can completetly reformat layer
fields with a friendly user interface.
In combination with existing modeler, it becomes relatively easy to
create full formatted data export models.
Arnaud
Le 23/01/2015 10:12, Arnaud Morvan a écrit :
> For now, it seems that all the points raised have been threated
> and commits rebased to avoid conflicts
> Reminder, here are the links to pull requests:
> https://github.com/qgis/QGIS/pull/1753
> https://github.com/qgis/QGIS/pull/1759
> Regards
> Arnaud
> Le 21/01/2015 13:14, Victor Olaya a écrit :
>> Thanks for the reminder. I added comments on both of the PR (once
>> should be almost ready to merge, the other one might need a bit more
>> discussion...)
>> Regards
>> 2015-01-21 12:23 GMT+01:00 Paolo Cavallini <cavallini at faunalia.it>:
>>>> You can find features description on pull requests pages
>>>> We feel both PR carry interesting enhancements and new
>>>> functionnalities
>>>> for processing.
>>>> Could you please confirm if you think it is OK for merging ?
>>> agreed, interesting stuff, thanks.
>>> Beware build is failing, however:
>>> https://travis-ci.org/qgis/QGIS/builds/47760579
>>> All the best.
>>> Paolo Cavallini - www.faunalia.eu
>>> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
