[Qgis-developer] Possible bug with select in a rectangle - Correction
Zoltan Szecsei
zoltans at geograph.co.za
Mon Jan 26 00:34:06 PST 2015
Hi Again,
I have now managed to check QGIS tracking, and couldn't find any similar
issues.
I can't be sure about the bit in red strikethrough below, so ignore that
part.
Regards,
Zoltan
On 2015/01/26 09:08, Zoltan Szecsei wrote:
> Hi Guys,
> I tried to go to QGIS issue tracking, but was told that the "site was
> under heavy load", so haven't checked if this is a known issue.
> Platform is Ubuntu 14.10 with self-compiled QGIS 1614ac8.
> Scenario:
> I have a shape file with some 700K points, and a raster image covering
> about 10 of these points.
> I want to delete all except these 10 points.
> Try #1
> I select my 10 points, open the attribute table and click invert
> selection.
> I then click the red bin (delete selected) and wait (I left it
> going overnight)
> The next morning I killed the task and when I re-opened the point
> file, my 10 points were deleted and the rest were still there.
> Clue: I might have clicked delete selected before the 'invert
> selection' had finished. This would be due to the fact that I may
> not have seen (if any) indication that the invert selection task
> had completed.
> Try #2
> I zoom to the extents of the point file, turn off rendering of the
> point file, turn on editing in the point file.
> I then select (invisible) features from this point file in a large
> rectangle above my visible raster image.
> After a few second I get no indication that anything is selected,
> and the 'delete selected' icon remains grey.
> I turn on rendering for the point shape file, and those that were
> in my rectangle are rendered in yellow (ie: 'selected')
> I open the attribute table and the 'delete selected' icon IS red,
> and I can move my selection to the top.
> I then delete the selection from the attribute table as the icon
> on the toolbar is still not 'available'.
> After 10 minutes or more, I get tired of waiting and kill the job.
> Try #3
> I re-open the point file, leave rendering on, select the same
> points as in try #2 above, and click 'delete selected'.
> After 2-3 minutes or so, the selected points are deleted as expected.
> So, I've raised a few issues here, but they seem to be centred on the
> attribute table being open.
> Regards,
> Zoltan
Zoltan Szecsei PrGISc [PGP0031]
Geograph (Pty) Ltd.
GIS and Photogrammetric Services
P.O. Box 7, Muizenberg 7950, South Africa.
Mobile: +27-83-6004028
Fax: +27-86-6115323 www.geograph.co.za
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150126/79aca8b7/attachment.html>
