[Qgis-developer] Difference between two layers doesn't remove any features
Anita Graser anitagraser at gmx.at
Thu Jul 2 11:48:17 PDT 2015
On Thu, Jul 2, 2015 at 8:02 PM, Etienne Trimaille <
etienne.trimaille at gmail.com> wrote:
> Nobody confirms this bug in 2.10 ?
​I just tried in master with QGIS sample data and difference worked fine.
Have to install 2.10 to try.
Best wishes,
Anita​
> The layer produced by the 'difference' tool in QGIS can't be used in a
> further analysis because of invalid geometries.
> "Difference" is used in many GIS analysis. This is a regression for me.
> 2015-06-29 16:27 GMT+02:00 Etienne Trimaille <etienne.trimaille at gmail.com>
>> Hi dev,
>> I'm using qgis master and I'm trying to use the difference tool between
>> two layers (from the vector menu and processing).
>> On the map canvas, the result looks fine, I get less features displayed.
>> However my result layer contains exactly the same number of features than
>> my original layer.
>> Running the "check validity" from processing, I get a lot of "Unknown
>> geometry type 0".
>> I can't use this layer in any processing algorithm :
>> "QgsFeature.setGeometry(QgsGeometry): argument 1 has unexpected type
>> 'NoneType'"
>> I don't know which algorithms may be affected by this kind of bug.
>> It's working fine on qgis 2.8.
>> Regards,
>> Etienne
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150702/d0f106a7/attachment.html>
