[Qgis-developer] error during compilation
Matteo Ghetta matteo.ghetta at gmail.com
Tue Jul 7 06:47:31 PDT 2015
It seems that the problem is solved deactivating GRASS (both 6 and 7).
I'll try to make more tests.
Hope this help
Cheers
Matteo
2015-07-06 23:32 GMT+02:00 Matteo Ghetta <matteo.ghetta at gmail.com>:
> Hi all,
> I have a problem during the compilation on QGIS master on debian testing.
> After the configuration with ccmake I get this error:
> [ 46%] Building C object
> src/providers/grass/6/CMakeFiles/qgis.d.rast6.dir/__/qgis.d.rast.c.o
> /home/ma7730/lavori/QGIS/QGIS-Master/src/providers/grass/qgis.d.rast.c: In
> function ‘cell_draw’:
> /home/ma7730/lavori/QGIS/QGIS-Master/src/providers/grass/qgis.d.rast.c:259:23:
> error: ‘INT_MIN’ undeclared (first use in this function)
>              int nul = INT_MIN;
> note: each undeclared identifier is reported only once for each function it
> appears in
> src/providers/grass/6/CMakeFiles/qgis.d.rast6.dir/build.make:54: recipe
> for target
> 'src/providers/grass/6/CMakeFiles/qgis.d.rast6.dir/__/qgis.d.rast.c.o'
> failed
> make[2]: ***
> [src/providers/grass/6/CMakeFiles/qgis.d.rast6.dir/__/qgis.d.rast.c.o]
> Error 1
> CMakeFiles/Makefile2:2129: recipe for target
> 'src/providers/grass/6/CMakeFiles/qgis.d.rast6.dir/all' failed
> make[1]: *** [src/providers/grass/6/CMakeFiles/qgis.d.rast6.dir/all] Error
> 2
> Makefile:146: recipe for target 'all' failed
> make: *** [all] Error 2
> could it be a problem related with grass6 vs grass7?
> Thanks to all|
> Matteo
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150707/921b448b/attachment-0001.html>
