[Qgis-developer] Conflits between owsLib packages in OSGeo4w and QGIS
Paolo Cavallini
cavallini at faunalia.it
Fri Jul 24 03:38:21 PDT 2015
Il 24/07/2015 12:35, Alexandre Neto ha scritto:
> OSWLib is now packed with QGIS, making it very convenient to use in
> plugins. Yet, using the OSGeo4w installer the user can install another
> version of OWSLib, but with another version (0.7.x). And in this case,
> our plugin fail to open, because it tries to use the 0.7 version instead
> the one packed inside QGIS.
> Besides telling the user to uninstall the 0.7 version (the current
> workaround), is there a way to make sure that the plugin use the currect
> OSWLib version? Could someone point me to an example?
Hi Alexandre,
this is a known issue: the internal lib should be removed, and the
shared one used instead. The main dev is aware of this, probabkly he
just need a hand.
Could you perhaps give a hand?
All the best, and thanks.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
