[Qgis-developer] Looping over features in processing
Victor Olaya volayaf at gmail.com
Fri Jul 24 22:38:30 PDT 2015
Unfortunately, there is not configuration for the output names, it just
uses the input name you enter for the output and add numbers as a suffix.
Being able to use an attribute value instead of numbers sounds to me like a
nice improvement, so if you can open a feature request, i will work on it
when i have some time.
Let me know if you have more ideas
Cheers
2015-07-24 21:22 GMT+02:00 Tim Sutton <tim at qgis.org>:
> Hi
> On 24 Jul 2015, at 20:06, Paolo Cavallini <cavallini at faunalia.it> wrote:
> Ah thanks, got it now. Any idea how I can write the output layers out with
> e.g.
> <feature_name>_roads.shp
> <feature_name>_buildings.shp
> (I’m basically trying to iteratively loop through wards, clipping out all
> the roads and buildings for each ward to a file named on the ward name).
> Also being able to put the date into the name would be great.
> Regards
> Tim
> Just click on the small green arrow besides layer name.
> Cheers.
> Il 24 luglio 2015 18:40:33 CEST, Tim Sutton <tim at qgis.org> ha scritto:
>> Hi
>> On 23 Jul 2015, at 22:44, Tim Sutton <tim at qgis.org> wrote:
>> Hi Victor
>> On 23 Jul 2015, at 22:18, Victor Olaya <volayaf at gmail.com> wrote:
>> Tim
>> What you are describing is the behaviour of the iterative execution of
>> algorithms (for a layer with n features, it runs the algorihtm n times,
>> each of them using as input a layer with only one of those features). That
>> can be executed without the need to code anything, from the algorithm
>> dialog.
>> Yeah that sounds exactly like what I am after. I will go and take a look
>> at that.
>> Sorry to be a bit slow here - I went back to try this and couldn’t see
>> where / how to do it - can you give a few more pointers?
>> Thanks!
>> Regards
>> Tim
>> Thanks!
>> Regards
>> Tim
>> If it's not exactly what you are looking for and you want to code
>> something similar, maybe you can at least check the corresponding code to
>> get some ideas
>> https://github.com/qgis/QGIS/blob/master/python/plugins/processing/gui/AlgorithmExecutor.py#L58
>> Let me know if you have more questions
>> Cheers
>> 2015-07-23 20:15 GMT+02:00 Tim Sutton <tim at qgis.org>:
>>> Hi all
>>> Is it possible to write loops in processing. I’d like to do stuff like
>>> iterate over each poly in a polygon layer, clip features from a few layers
>>> and write them to a subfolder whose name is based on the name of the
>>> polygon layer. Think of it like atlas but for data not for print
>>> compositions. Has anyone done something similar?
>>> Regards
>>> Tim
>>> <PastedGraphic-1.tiff>
>>> Tim Sutton
>>> QGIS Project Steering Committee Member
>>> tim at qgis.org
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Tim Sutton
>> tim at qgis.org
>> Tim Sutton
>> tim at qgis.org
> Paolo Cavallini
> http://www.faunalia.eu
> Tim Sutton
> tim at qgis.org
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150725/fecd5622/attachment-0001.html>
Type: image/tiff
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150725/fecd5622/attachment-0001.tiff>
