[Qgis-developer] Lizmap - show table in one to many relationship
kimaidou kimaidou at gmail.com
Wed Jul 29 00:24:35 PDT 2015
Hi Pietro,
This feature has landed in Lizmap master, but is not available for current
stable version. We are about to publish a 3.0 beta version to let users
test it and report possible bugs. If you want to try this new feature, you
need:
* last Lizmap Web Client ( master version, available for download on github)
* last Lizmap plugin ( master version, available in github too)
* Configure relations in QGIS for the layers you need
* Add you layers in the "Attribute layers" tab in Lizmap plugin (and
publish them as WFS). If you have "many yo many" relationships between
layers, such as bus lines <-> pivot table <->bus stops, you can check the
checkbox "pivot table" for the middle table.
Lizmap "master" is not going to change a lot until we release the 3.0 :
only small enhancements and debug. You can use it with confidence.
Regards
Michaël
2015-07-28 11:35 GMT+02:00 Pietro Rossin <pierigis at gmail.com>:
> Hello everybody
> I'm learning Lizmap and in general Webgis so my question could be trivial.
> I must publish some layers in Lizmap that have many documents relative to a
> single record.
> Let's say an area has lots of papers about studies made on it.
> My data are in postgis tables and I can make a table on "many" side with
> one
> record for each document and an id connecting to the "one" side table.
> Is there some easy way to open a table with all the "many" record for the
> single feature clicked?
> Directly by Lizmap or by a link that point to a table popup?
> My setup is Lizmap 2.11 on debian server, qgis-server 2.8
> Thanks
> http://osgeo-org.1560.x6.nabble.com/Lizmap-show-table-in-one-to-many-relationship-tp5217320.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150729/e4d853be/attachment.html>
