[Qgis-developer] Simplified Processing interface doesn't list GRASS algos
Lene Fischer lfi at ign.ku.dk
Wed Jul 29 03:08:04 PDT 2015
When a user start to use Processing - they are not any longer beginners :-)
Regards
Lene Fischer
-----Oprindelig meddelelse-----
Fra: qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-bounces at lists.osgeo.org] På vegne af Victor Olaya
Sendt: 29. juli 2015 11:55
Til: Anita Graser
Cc: qgis-developer
Emne: Re: [Qgis-developer] Simplified Processing interface doesn't list GRASS algos
The idea of the simplified interface was to have an interface that was more understandable for users with less experience, so you do not have to know if the algorithm comes from GRASS, SAGA or whatever. That might be useful for advanced users, but it is confusing for the rest of them.
Also, if an algorithm is repeated in several backends, only one of them is added to the simplified interface, eliminating the need to select one of them (also confusing for users)
GRASS algorithms are not featured in the simplified interface since, although they are wrapped as Processing algorithms and simplified as much as possible, you still have to know something about GRASS and its data structures to use them correctly and not get strange behaviour.
If you want to use a GRASS, algorithm, I am assuming you are an advanced user, so you can go to the advanced interface.
These were my initial ideas, but if the simplified interface is causing more confusion than good....I will be happy to take it away (it will save us devs quite a bit of work...). However, IMHO, it is a much better UI for most of user, but I would like to hear what people think.
Thanks for your comments!
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
