[Qgis-developer] memory layer performance while adding many features?
Denis Rouzaud
denis.rouzaud at gmail.com
Wed Jul 29 23:46:52 PDT 2015
Hi Raymond,
Can you show us the code doing this?
Do you commit features one by one ar all at once?
Best wishes,
Denis
On 07/29/2015 09:04 AM, Raymond Nijssen wrote:
> Dear developers, ;)
> A plugin of mine imports data from a gml file into a memory layer.
> Works fine for tiny gml files, but takes forever on huge ones. Sounds
> plausible maybe, but the relation is not linear.
> So I did did some tests and found out that reading and parsing the gml
> and creating the features always goes at the same speed of about 400
> features a second (fps). But when adding these to my memory layer, the
> process slows down tremendously.
> I output the fps for every 1000 features and it gave me this graph:
> http://terglobo.nl/downloads/memory-layer-performance.png
> At the end of the importing process I'm processing just 3 features per
> second.
> Is this expected behaviour? Is a memory layer not meant for something
> like this? Or is this a bug?
> In the source code I found that for every feature I add to a memory
> layer the index is updated. Could that be inefficient?
> Hoping anyone can explain!
> Regards,
> Raymond
