[Qgis-developer] memory layer performance while adding many features?
Denis Rouzaud denis.rouzaud at gmail.com
Thu Jul 30 00:34:12 PDT 2015
 From your code [0] , I would see 2 options:
* add features all at once on the provider using
QgsVectorDataProvider::addFeatures (the method you currently use)
* work on the layer level rather than the provider, which I believe is
the recommended way for plugins. Make the layer editable, and add
features to the edit buffer and commit at once. Or maybe commit 1000 by
1000.
I hope this helps.
[0]
https://github.com/opengeogroep/AERIUS-QGIS-plugins/blob/master/ImaerReader/imaer_reader.py#L228
On 07/30/2015 09:20 AM, Raymond Nijssen wrote:
> Hi Denis,
> The code is in the ImaerReader plugin in the qgis repo and in github:
> I'm adding the features one by one.
> Regards,
> Raymond
> On 30-07-15 08:46, Denis Rouzaud wrote:
>> Hi Raymond,
>> Can you show us the code doing this?
>> Do you commit features one by one ar all at once?
>> Best wishes,
>> Denis
>> On 07/29/2015 09:04 AM, Raymond Nijssen wrote:
>>> Dear developers, ;)
>>> A plugin of mine imports data from a gml file into a memory layer.
>>> Works fine for tiny gml files, but takes forever on huge ones. Sounds
>>> plausible maybe, but the relation is not linear.
>>> So I did did some tests and found out that reading and parsing the gml
>>> and creating the features always goes at the same speed of about 400
>>> features a second (fps). But when adding these to my memory layer, the
>>> process slows down tremendously.
>>> I output the fps for every 1000 features and it gave me this graph:
>>> http://terglobo.nl/downloads/memory-layer-performance.png
>>> At the end of the importing process I'm processing just 3 features per
>>> second.
>>> Is this expected behaviour? Is a memory layer not meant for something
>>> like this? Or is this a bug?
>>> In the source code I found that for every feature I add to a memory
>>> layer the index is updated. Could that be inefficient?
>>> Hoping anyone can explain!
>>> Regards,
>>> Raymond
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150730/4572a8a1/attachment.html>
