[Qgis-developer] function similar to Excel VLOOKUP
Roy
royroge at outlook.com
Thu Jul 30 05:34:19 PDT 2015
How about a " Join "
QGIS join
Il 30/07/2015 13.06, Zoltan Szecsei ha scritto:
> Hi,
> How could I implement something like vlookup in QGIS?
> I have a shapefile with 2000 polygons and column 1 of its attribute
> table has a code value.
> Using the code in this column 1, I need to look up which row of a CSV
> file has that code, and return column 2 of the CSV file.
> This returned value must then be placed into a new column (say column
> 6) on the shapefile attribute table.
> I could pre-add the new column to this shapefile, and then run the
> vlookup equivalent too, of course.
> I tried this by opening the DBF file in Libreoffice calc, sorting the
> columns, adding the extra two columns of my lookup data, then ran
> vlookup and saved/closed the DBF file.
> Once back in QGIS the attributes ended up being linked to the wrong
> polygons (probably because I sorted the DBF file outside of QGIS).
> Thanks in advance,
> Zoltan
