[Qgis-developer] function similar to Excel VLOOKUP - SOLVED
Zoltan Szecsei
zoltans at geograph.co.za
Thu Jul 30 06:08:53 PDT 2015
Awesome. Thank you.
I added the extra column to the shapefile attributes, joined the
shapefile to the CSV file, and then updated the new column in my
shapefile using:
attribute($currentfeature,'joinedcolumn') (NOTE: single quotes for
field name)
I'm sure I could have skipped the Join step and just used getfeature as
suggested below, but I went the Join route anyway.
Big thanks,
Zoltan
On 2015/07/30 14:34, DelazJ wrote:
> Hi,
> I think combining getFeature and attribute functions should help u do
> that in the field calculator, though I haven't used them on csv files.
> Assuming col1 in your csv contains also the code you are looking for,
> applying this expression on shapefile "col 6" in QGIS field calculator
> may do the job:
> attribute (getFeature ('mycsvfile', 'mycsv_col1', "myshape_col1"), 'col2')
> Regards,
> DelazJ
> 2015-07-30 13:06 GMT+02:00 Zoltan Szecsei <zoltans at geograph.co.za
> <mailto:zoltans at geograph.co.za>>:
> Hi,
> How could I implement something like vlookup in QGIS?
> I have a shapefile with 2000 polygons and column 1 of its
> attribute table has a code value.
> Using the code in this column 1, I need to look up which row of a
> CSV file has that code, and return column 2 of the CSV file.
> This returned value must then be placed into a new column (say
> column 6) on the shapefile attribute table.
> I could pre-add the new column to this shapefile, and then run the
> vlookup equivalent too, of course.
> I tried this by opening the DBF file in Libreoffice calc, sorting
> the columns, adding the extra two columns of my lookup data, then
> ran vlookup and saved/closed the DBF file.
> Once back in QGIS the attributes ended up being linked to the
> wrong polygons (probably because I sorted the DBF file outside of
> QGIS).
> Thanks in advance,
> Zoltan
> Zoltan Szecsei PrGISc [PGP0031]
> Geograph (Pty) Ltd.
> GIS and Photogrammetric Services
> P.O. Box 7, Muizenberg 7950, South Africa.
> Mobile: +27-83-6004028 <tel:%2B27-83-6004028>
> Fax: +27-86-6115323 <tel:%2B27-86-6115323> www.geograph.co.za
> <http://www.geograph.co.za>
> Qgis-developer mailing list
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
Geograph (Pty) Ltd.
Fax: +27-86-6115323 www.geograph.co.za
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150730/f8fd5653/attachment-0001.html>
