[Qgis-developer] Releases roadmap on the website
Sandro Santilli strk at keybit.net
Fri Jul 31 04:30:41 PDT 2015
On Fri, Jul 31, 2015 at 01:12:06PM +0200, Richard Duivenvoorde wrote:
> On 31-07-15 13:03, Sandro Santilli wrote:
> >> IF you add it, be sure to use the right notation to make it
> >> translatable: {{_('text here')}}
> > Thanks. Again, is there a way to "preview" changes ?
> Nope. Edits in the RST pages are rendered in Github, but those html
> templates are not.
> So only way to check is the next day when the website is rebuild and
> updated.
Would it be any easy/useful to have a "staging" website to see changes
as they are pushed in a special branch ?
> Or you rebuild it yourself, which (if you like Docker :-) ) is now even
> easier... I have to add the instructions to the website/docs readme's
> but the instructions are like here:
> https://github.com/AIFDR/inasafe-doc#docker-build-on-your-machine
Thanks, I'll get to learn docker one day :)
--strk;
