[Qgis-developer] Data-defined symbol size is not backwards compatible to 2.8.2
Andreas Neumann a.neumann at carto.net
Mon Jun 1 08:14:33 PDT 2015
Regarding data-defined symbol size:
I noticed that some of my old 2.8x projects display different in QGIS
master - the symbols that have a data-defined size with a very simple
CASE WHEN rule display much bigger in QGIS master than in the 2.8x branch.
So I wonder, what exactly has changed in master regarding symbol size
and why?
Thanks,
Andreas
On 31.05.2015 15:27, Régis Haubourg wrote:
> HI,
> we are sponsoring Vincent Mora on that and I submitted the issue on Friday.
> He should be able to work on that in the next few days.
> Cheers
> Régis
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Data-defined-symbol-size-is-not-backwards-compatible-to-2-8-2-tp5208256p5208310.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
