[Qgis-developer] error during compiling [libproj.so]
Matteo Ghetta matteo.ghetta at gmail.com
Sat Jun 6 02:30:35 PDT 2015
Hi Sebastiaan,
thanks for your help.
I checked and I have libproj9 already installed.
So what exacly should I do? Should I re-run ccmake in order to have another
list of all the paths?
Thanks!
Matteo
2015-06-06 11:25 GMT+02:00 Sebastiaan Couwenberg <sebastic at xs4all.nl>:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA512
> On 06/06/2015 11:12 AM, Werner Macho wrote:
> > Where on your system is "libproj.so.0" located?
> He runs Debian testing, which ships proj 4.9.1 (libproj.so.9) since a
> few weeks.
> With the update to 4.9.1 the library moved to Multi-Arch directories,
> so: /usr/lib/<triplet>/libproj.so.9
> The errors are about the old paths for proj 4.8.0, and that's no
> longer available in Debian testing. Rebuilding qgis with the proj
> 4.9.0 (with libproj-dev installed) should just work, it helps to
> always build in a clean cowbuilder chroot.
> Kind Regards,
> Bas
>  GPG Key ID: 4096R/6750F10AE88D4AF1
> Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v2
> iQIcBAEBCgAGBQJVcryYAAoJEGdQ8QrojUrxRW0QAMq/Lih4zMZ3v9Z3Wz97wfv5
> H500rkZ9CwkzcRy3YZRUcKQZqv6eP55rMGPh4O7wJaFTulruLwF83UI5w8tg720p
> 1OuNk2EtGR7RJMcpB0jAQSIGce9Z573axwpRTjqx1A+uJN/rbnMOFP5CNoJfhI+L
> i1iOSKs7/ymtFrkab/wHwuMQBNs0hqDG4UZF1NqGOOQIcpXhXSO/jsO+tzV+wZU0
> YDrW3apPri4/rWGmAkyUj+mlClNgmy5Id09aed9xc/rQNwTW7+L4hVX8hYkukIp4
> 7gDKhV+vhS0hzDhhEXCv5MVE5VAchTMgrFj+jp7M0LYWsVSw9lw3DHXNLNv8wHMu
> ffF/fF5t/4Gi2hMvUK4ee6UQTG1KM4QMZKUR2OUTwyu5v8Nji84ZMkjm4/v7dYQ9
> 8RAy7FDNsNDDcOlmmBpEi7fPEDBCs043G6xnqrkbR7Fvo+RYuScf4FfAwg2ckr3m
> vTj+A/s4tG6Nx9845NEIumDvNqnAXdD8DIdu89FLe0I0M0GtKLpHwREiyESw/LHp
> 4oI4evOb1KFjalebmkuSqG7BsRS4K4IoXfZQXUJgXw3ud77ohL/REofqHN2P+7OU
> PyJ3DsRRqRFtxXNF6Y4fT9hiDAC7wY+ojm+QM9vJzBkrPAGtVBerIu/YFQn7t9OC
> aGYLmh8OLYZnktTRLqU4
> =QeED
> -----END PGP SIGNATURE-----
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150606/135c66bb/attachment.html>
