[Qgis-developer] Persist plugin GUI dialog settings
Tom Chadwin
tom.chadwin at nnpa.org.uk
Sat Jun 6 03:15:41 PDT 2015
Thanks, Richard. That would work perfectly, but my UI is mostly QTreeWidgetItem elements. Apparently, those don't emit valueChanged signals, so I can't use your code (unless I've got that wrong). I therefore either have to find some other signal I can hook into, or save the settings at some other point. Any ideas?
-------- Original message --------
From: "Richard Duivenvoorde [via OSGeo.org]" <ml-node+s1560n5209443h23 at n6.nabble.com>
Date: 05/06/2015 16:08 (GMT+00:00)
To: Tom Chadwin <tom.chadwin at nnpa.org.uk>
Subject: Re: Persist plugin GUI dialog settings
On 05-06-15 16:34, Tom Chadwin wrote:
> OK, so I have found the documentation which says I should use QSettings(),
> which is clear enough, and I can read settings in fine. However, if I want
> my plugin settings to persist transparently (ie the user should not have to
> save the settings explicitly), where in the plugin should I put all my
> QSettings().value("key", "value") statements?
Not sure if it is the best way, but actually whenever the user changes
something (by clicking or inputting something) you can 'save' it to
settings.
As an example:
https://github.com/rduivenvoorde/featuregridcreator/blob/master/FeatureGridCreator/grid_creator.py#L173
I create two helper functions to set and get settings value (and make it
possible to return a default value in case setting is not set).
and all the getter setter's are used when the user clicks (changes)
something in the dialog. So the settings are being constantly in sync
with the user latest choices...
But there are probably other ways too :-)
Regards,
Qgis-developer mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-developer
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/Persist-plugin-GUI-dialog-settings-tp5160325p5209443.html
To unsubscribe from Persist plugin GUI dialog settings, click here<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5160325&code=dG9tLmNoYWR3aW5Abm5wYS5vcmcudWt8NTE2MDMyNXwxNDg2MTk5Mjcx>.
NAML<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
Tom Chadwin, ICT Manager
Telephone: 01434 611530 Mob:
Web: www.northumberlandnationalpark.org.uk<http://www.northumberlandnationalpark.org.uk/>
IMPORTANT NOTICE - Disclaimer - This communication is from Northumberland National Park Authority (NNPA).The Authority’s head office and principal place of business is Eastburn, South Park, Hexham, Northumberland, NE46 1BS, United Kingdom. If you are not the intended recipient(s) please note that any form of disclosure, distribution, copying or use of this communication or the information in it or in any attachments is strictly prohibited and may be unlawful. If you have received this communication in error, please delete the email and destroy any copies of it. Any views or opinions presented are solely those of the author and do not necessarily represent those of NNPA.Contractors or potential contractors are reminded that a formal Order or Contract is needed for NNPA to be bound by any offer or acceptance of terms for the supply of goods or services Although this email and any attachments are believed to be free of any virus or other defects which might affect any computer or IT system into which they are received, no responsibility is accepted by the NNPA for any loss or damage arising in any way from the receipt or use thereof. Computer systems of this Authority may be monitored and communications carried out on them recorded, to secure the effective operation of the system and for other lawful purpose.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Persist-plugin-GUI-dialog-settings-tp5160325p5209522.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150606/60fe1738/attachment-0001.html>
