[Qgis-developer] Processing log: not saved?
Paolo Cavallini
cavallini at faunalia.it
Sun Jun 7 23:35:09 PDT 2015
Il 08/06/2015 07:02, Victor Olaya ha scritto:
> You still have the same output as before. Everything that was logged
> into the Processing log is now in a "Processing" tab in the QGIS log.
> The only thing left in the sepoarate Processing history are the
> executed commands, since that is an interactive log (you can double
> click on a history entry to re-run the alg) and that cannot be
> implemented in the QGIS log
> So, in short, you have the same info, just with a more coherent
> structure for a core plugin, as it was mentioned before
Hi Victor,
thanks for clarifying. The current approach makes a lot of sense;
however, I believe Processing is a special case, in which it is rather
common for an user to want to save all the output for future reference
and inspection. Selecting all, copying and pasting to a file is quite
impractical. Perhaps better to add an option to flush all the output to
a file?
All the best.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
