[Qgis-developer] Bug in symbol size data-defined override
Andreas Neumann a.neumann at carto.net
Mon Jun 8 06:46:17 PDT 2015
I agree - a rename to "size assistant" or "sizing assistant" would be
useful. In my opinion, the new solution is not harder to find than the
old solution - which was pretty hard to find and even more disconnected
to the actual symbol than the new solution. I agree, it is still a bit
hidden, but it belongs to the expression - that's why the current
solution isn't bad.
Andreas
On 08.06.2015 15:26, Régis Haubourg wrote:
> Alexandre Neto wrote
>> Not sure if data-defined override for Symbol Size should even be connected
>> to the size-scale method, since in this case it should simply override the
>> symbol size value.
> In master UI refactoring, area or diameter selector disappeared, and we now
> have an assistant for that.
> Expressions directly typed refer to size (diameter) and are no more
> influence by this modifier.
> I think we should rename 'assistant' by 'size assistant' so that users see
> that more easily, and maybe put it in bold font.  I'm afraid that they won't
> see that tool because they are very used to this widget.
> Thoughts?
> Cheers
> Régis
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Bug-in-symbol-size-data-defined-override-tp5209442p5209752.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
