[Qgis-developer] Problem compiling master can't find qwtpolar dir
Alexandre Neto senhor.neto at gmail.com
Fri Jun 12 01:22:28 PDT 2015
Thanks Matteo,
I did not found that thread earlier.
I will try it that way.
Alexandre
On Fri, Jun 12, 2015 at 8:19 AM, Matteo Ghetta <matteo.ghetta at gmail.com>
wrote:
> HI Alexandre,
> I had the same problem..
> You can read this thread and you should be able to solve the problem:
> http://lists.osgeo.org/pipermail/qgis-developer/2015-February/036602.html
> Cheers
> Matteo
> 2015-06-12 0:21 GMT+02:00 Alexandre Neto <senhor.neto at gmail.com>:
>> I used to be able to complile QGIS master in ubuntu 14.04 without any
>> problems. Now I get some erros during ccmake ..
>> It's not able to find qwtpolar nor qsci_sip_dir
>>  QSCI_SIP_DIR                     QSCI_SIP_DIR-NOTFOUND
>>  QWTPOLAR_INCLUDE_DIR             QWTPOLAR_INCLUDE_DIR-NOTFOUND
>>  QWTPOLAR_LIBRARY                 QWTPOLAR_LIBRARY-NOTFOUND
>> Can someone give me some hint to solve this?
>> Thanks
>> Alexandre Neto
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150612/82526172/attachment.html>
