[Qgis-developer] Bug priority for release
Paolo Cavallini
cavallini at faunalia.it
Sat Jun 13 02:30:37 PDT 2015
Il 12/06/2015 15:02, Jürgen E. Fischer ha scritto:
> The workaround for this (see 86d08b6c) - until the sql expression are there -
> is to set the initial mode for the attribute table to "only visible on map" in
> options. That will request only the features in the current canvas.
> Note that this is different from what you can set in the attribute table
> itself. If set in options the attribute table will always be tied to canvas
> extent it was opened with - so "show all" within such a table will again only
> show the features in the initial canvas extent - "show only visible" will still
> have an effect if you zoom in.
Thanks a lot, clear now.
Documenters: better adding a note on the manual? This is not very
obvious for users.
All the best.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150613/05d17e1c/attachment.pgp>
