[Qgis-developer] Export atlas composition to a single PDF file
DelazJ
delazj at gmail.com
Thu Jun 18 03:29:08 PDT 2015
Following that discussion, I'm planning to release in a couple of weeks a
new version of **Maps Printer** plugin that will export also atlases. I'm
not sure the code I have in github is enough stable yet. Will give it a
look soon.
Meanwhile, You can see the code of **Surveying Calculation** plugin
(bacth_plotting_dialog.py). It exposed a kind of python code of the needed
function.
2015-06-18 12:02 GMT+02:00 Nyall Dawson <nyall.dawson at gmail.com>:
> On 18 June 2015 at 19:46, David Erill <daviderill79 at gmail.com> wrote:
> > Hi devs!
> > I need to Export atlas composition to a single PDF file.
> > I have the same problem as the one exposed in this thread:
> > http://lists.osgeo.org/pipermail/qgis-user/2014-August/028744.html
> > Is that functionality already resolved through Python code?
> No, unfortunately nothing's changed regarding that yet.
> Nyall
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150618/dfe78153/attachment.html>
