[Qgis-developer] Moving map content: interference by overlying objects
Andreas Neumann a.neumann at carto.net
Thu Jun 18 11:19:02 PDT 2015
Hi Paolo,
You can lock the elements that are on top of the map so they don't
"steel" the events. When I work in print composer, 90% of my elements
are locked and only occasionally unlocked if I really want to move
things around. You have to work more with the item tree (like in any
drawing app). Note that you can still select locked items in the item
tree and can change properties of locked items. Only interactive
selection in the canvas and moving elements is locked if they are in
lock state.
Andreas
On 18.06.2015 18:07, Paolo Cavallini wrote:
> Hi all,
> in Print composer, if an object (e.g. an ellipse) overlays partly or
> totally a map, it will not allow to move the content of the selected map
> below it. I can understand the rationale, but I believe that once
> selected the map should be movable. This is especially unexpected in
> case of an unfilled ellipse|rectangle|triangle.
> More generally, I got accustomed to using the move content, but I still
> think it's a bit cumbersome, and a better system could possibly be
> devised. How similar software behave?
> All the best, and thanks.
