[Qgis-developer] ELSE expression is used when other rules are set not visible - Feature or Bug?
Andreas Neumann
a.neumann at carto.net
Sat Jun 20 07:05:23 PDT 2015
Exactly - these are good terms to use - "disabled rule" and "invisible
rule". Thanks for suggesting these, Andreas. Alexandre - could you
please note this in the ticket?
Andreas
On 19.06.2015 16:33, Matthias Kuhn wrote:
> Just my 2 cents on a topic I know nothing about :)
> ... or we can have a "disable rule" and an "invisible rule". Disabled
> rules go to ELSE, invisible rules don't go to ELSE.
> Cheers
> On 06/19/2015 04:13 PM, Alexandre Neto wrote:
>> So, can I open a ticket?
>> Alexandre
>> On Fri, Jun 19, 2015 at 12:50 PM, Andreas Neumann
>> <a.neumann at carto.net <mailto:a.neumann at carto.net>> wrote:
>> In my opinion this is a bug. I agree that by switching off the
>> rule should not make the features fall into the ELSE rule. At
>> least from a usability point of view. Or we need to ELSE rules -
>> a "TRUE ELSE" rule that behaves like now and an "ELSE" rule that
>> behaves like the users expect it to behave.
>> Andreas
>> On 19.06.2015 13:36, Etienne Trimaille wrote:
>>> I've this kind of bug too.
>>> If you create a categorized symbology, apply the change and then
>>> switch to a ruled-based symbology (keeping the previous rules),
>>> you will see that the ELSE statement will draw features twice.
>>> Enable "show feature count" to check.
>>> I didn't check if there is a ticket for that.
>>> 2015-06-19 13:18 GMT+02:00 Alexandre Neto <senhor.neto at gmail.com
>>> <mailto:senhor.neto at gmail.com>>:
>>> Indeed Nathan,
>>> But do you thinks that is what you were expecting? when you
>>> turn the "layer" off?
>>> Alexandre
>>> On Fri, Jun 19, 2015 at 12:08 PM, Nathan Woodrow
>>> <madmanwoo at gmail.com <mailto:madmanwoo at gmail.com>> wrote:
>>> I would say they are getting skipped in the rule check
>>> so fall into the else rule.
>>> On Fri, 19 Jun 2015 9:05 pm Alexandre Neto
>>> <senhor.neto at gmail.com <mailto:senhor.neto at gmail.com>>
>>> wrote:
>>> Using the rule-based symbology with several rules
>>> and an ELSE expression. If you, in map canvas
>>> legend, set a rule "layer" to invisible, all it's
>>> features will be represented with the ELSE Symbol.
>>> Not sure if this is the expected behaviour. I would
>>> expect that those feature would simply became invisible.
>>> Should I open a ticket?
>>> Thanks,
>>> Alexandre Neto
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> <mailto:Qgis-developer at lists.osgeo.org>
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150620/cc8d0d30/attachment-0001.html>
