[Qgis-developer] Export atlas composition to a single PDF file
DelazJ
delazj at gmail.com
Sat Jun 20 09:29:52 PDT 2015
@David Glad to know this!
@siki, @Nyall a novice question : what does it need to expose this function
in the console (or python side) following the work already done in
"Surveying Calculation" plugin?
2015-06-18 13:17 GMT+02:00 David Erill <daviderill79 at gmail.com>:
> DelazJ,
> I've checked that code and it worked perfect!!
> Thanks a lot
> 2015-06-18 12:29 GMT+02:00 DelazJ <delazj at gmail.com>:
>> Hi,
>> Following that discussion, I'm planning to release in a couple of weeks a
>> new version of **Maps Printer** plugin that will export also atlases. I'm
>> not sure the code I have in github is enough stable yet. Will give it a
>> look soon.
>> Meanwhile, You can see the code of **Surveying Calculation** plugin
>> (bacth_plotting_dialog.py). It exposed a kind of python code of the needed
>> function.
>> 2015-06-18 12:02 GMT+02:00 Nyall Dawson <nyall.dawson at gmail.com>:
>>> On 18 June 2015 at 19:46, David Erill <daviderill79 at gmail.com> wrote:
>>> > Hi devs!
>>> > I need to Export atlas composition to a single PDF file.
>>> > I have the same problem as the one exposed in this thread:
>>> > http://lists.osgeo.org/pipermail/qgis-user/2014-August/028744.html
>>> > Is that functionality already resolved through Python code?
>>> No, unfortunately nothing's changed regarding that yet.
>>> Nyall
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150620/5e042576/attachment.html>
