[Qgis-developer] Building plugin for Print Composer
G. Allegri
giohappy at gmail.com
Mon Jun 22 02:12:17 PDT 2015
Hi Jacob.
For the moment it isn't possible to extend the Composer with custom
plugins. It's sonething that will be discussed for the next Report Engine
(QGIS > 3.0)
I've built a Python plugin that uses the composer widgets (composition,
items, etc.) within a custom interface but you can only use the building
blocks by yourself. E.g. you can open/create abd manage a composition
inside your own widget and add items to it. In your case they could be text
or html items, for header and footer.
giovanni
Il 22/giu/2015 15:18, "Jakob Lanstorp" <jlanstorp at gmail.com> ha scritto:
> Is it possibly to build a Python plugin minded for the print composer
> alone?
> -Need to build a plugin with a new button inside print composer that lists
> all labels in the composer in a new dialog for editing. This would be a
> tool
> for easy handling of complex header and footers in the layout for the
> novice
> user.
> Jakob Lanstorp
> http://osgeo-org.1560.x6.nabble.com/Building-plugin-for-Print-Composer-tp5212187.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150622/e9ca9e52/attachment.html>
