[Qgis-developer] Using TravisCI integration in Github for QGIS Python plugin
Akbar Gumbira
akbargumbira at gmail.com
Mon Jun 22 16:12:41 PDT 2015
By default in QGIS plugin builder you meant is here
https://github.com/g-sherman/Qgis-Plugin-Builder/blob/master/run-env-linux.sh#L6
?. If so, that is not the default if you install QGIS like this in Travis
https://github.com/AIFDR/inasafe/blob/develop/.travis.yml#L17. You can just
pass /usr as the argument when running run-env-linux.sh script
On Tue, Jun 23, 2015 at 1:19 AM, Tom Chadwin <tom.chadwin at nnpa.org.uk>
wrote:
> I've got a bit further with this, but have an embarrassingly basic
> question.
> I'm using Tim's Plugin Builder's run-env-linux.sh, but the default QGIS
> path
> doesn't seem to match where Travis installs QGIS to - is Travis running
> Ubuntu? Can anyone tell me what QGIS path I should pass to
> run-env-linux.sh?
> http://osgeo-org.1560.x6.nabble.com/Using-TravisCI-integration-in-Github-for-QGIS-Python-plugin-tp5207646p5212347.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
*Akbar Gumbira*
*Software Engineer*
*Geospatial, NLP, Data Mining, Machine Learning, Artificial Intelligence*
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150623/50ac0945/attachment-0001.html>
