[Qgis-developer] Use the style tab widget in a Python plugin
Martin Dobias wonder.sk at gmail.com
Tue Jun 23 08:23:13 PDT 2015
Hi Michael
The QgsRendererV2Widget is really just abstract base class meant to be
implemented by custom implementations of renderers.
I think you are looking for this:
from qgis.gui import *
w=QgsRendererV2PropertiesDialog(iface.activeLayer(),
QgsStyleV2.defaultStyle(), True)
w.show()
Cheers
Martin
On Tue, Jun 23, 2015 at 11:09 PM, kimaidou <kimaidou at gmail.com> wrote:
> Ok, it seems python bindings are missing here. Here is the console output
>>>> from qgis.core import *
>>>> rw = QgsRendererV2Widget( iface.activeLayer(), QgsStyleV2.defaultStyle()
> Traceback (most recent call last):
>   File "<input>", line 1, in <module>
> TypeError: qgis._gui.QgsRendererV2Widget represents a C++ abstract class and
> cannot be instantiated
> Too bad ;)
> 2015-06-23 16:38 GMT+02:00 kimaidou <kimaidou at gmail.com>:
>> Hum...
>> After digging a little deeper, I found something interesting in the Python
>> Cookbook [1]
>> It seems I need to use the class QgsRendererV2Widget
>> [1]
>> http://docs.qgis.org/testing/en/docs/pyqgis_developer_cookbook/vector.html#creating-custom-renderers
>> 2015-06-23 16:29 GMT+02:00 kimaidou <kimaidou at gmail.com>:
>>> Hi all,
>>> The LayerBoard plugin I made during the HF in "Nooooooooodebo" shows a
>>> table of all vector (and raster) layers and allows to edit some properties
>>> directly by editing the table cells, such as max and min scale, layer name,
>>> title and abstract, assign SRS, etc.
>>> I would like to display the content of the Style tab of the layer
>>> properties dialog in a panel right to the table. This tab will show the
>>> style interface refreshed whenever the user clicks on a layer in the tab,
>>> and let her/him change the style for this layer the same way we do via the
>>> layer properties dialog.
>>> I have searched a bit in the api and in the source code, but cannot find
>>> the right way to do so. I have not found a custom Widget which I can
>>> instantiate with the layer and wich will provide me all the logic
>>> underneath.
>>> Is this even possible ? Has anyone an idea of how to to this without
>>> rewriting all the code ( connection between ui elements and slots)
>>> Thanks in advance
>>> Michaël
> Qgis-developer mailing list
