[Qgis-developer] Potentially serious performance regression in new geometry - should 2.10 be delayed?
Nyall Dawson
nyall.dawson at gmail.com
Tue Jun 23 16:13:55 PDT 2015
On 24 June 2015 at 00:44, Marco Hugentobler
<marco.hugentobler at sourcepole.ch> wrote:
> Hi Nyall
>> I'm still a bit unclear as to where
>> you are taking these classes though. Is the intention that eventually
>> ALL operations will be done using QgsGeos?
> In the end, yes, everything should go through QgsGeometryEngine interface.
> There are two possibilities:
> 1. client code creates QgsGeos, calls prepare() on it and makes repeaded
> intersection(), etc. directly on QgsGeometryEngine. This can be done with
> master branch as is.
This sounds like the right approach to me, but I have a couple of
further questions:
- For methods which don't have a geos implementation (eg,
QgsGeometry::smooth ), should they just be implemented in the
QgsGeometryEngine base class?
- I'm a bit concerned about the usability of this approach for plugin
developers. It means that they'd need to be aware that QGIS uses geos
for these geometry operations and use that QgsGeos is the class
required for geometry relation/modification operations. That's not
obvious and could be a stumbling block for new PyQGIS developers. It
also locks these plugins then into using the geos engine, and if we
ever decided to switch to a different engine then the plugins would
also need to be updated.
Just thinking aloud here... is there a good reason we couldn't instead
move these geos implementations to QgsGeometryEngine itself and do
away with QgsGeos? Then, in the (unlikely?) situation that a geos
implementation is inferior to a native QGIS method we can
mix-and-match between geos and alternative implementations as
required.
> 2. client code uses QgsGeometry and calls intersection() on it. To benefit
> from prepared geometries, we would need to enhance QgsGeometry to cache
> QgsGeos and call prepare() the first time it is used.
> Thinking about it, version 1 might be better. We cannot know if the cached
> QgsGeos is really needed a second time and it might use more memory if not.
> In the first case, the client code knows if it is intended to do repeaded
> operations on the same geometry.
> What do you think?
>> Could we put a giant "NOT STABLE API AND MAY CHANGE" for
>> all these classes, so that we can address any unforeseen issues in
>> 2.12?
> That would be ok.
Great! That's my biggest reservation - if we've got the opportunity to
tweak the API for 2.12 then my fears have been unfounded :)
Thanks!
Nyall
