[Qgis-developer] Change vector layer data source
Andreas Neumann
a.neumann at carto.net
Wed Jun 24 05:25:36 PDT 2015
Hi Nathan,
So if it is only accessible to programmers then it should be moved into
the category "Programmability". Currently, it is listed under Plugins.
It would be cool if someone who knows could write some code snippet for
this entry to explain how to use it.
Thanks for letting me know,
Andreas
On 24.06.2015 14:16, Nathan Woodrow wrote:
> Hey Andreas,
> That is a API only change the moment for vector layers only.
> There was a bug in the method which Nyall has fixed in the last few
> days so you might be on a older version.
> Regards,
> Nathan
> On Wed, Jun 24, 2015 at 10:06 PM, Andreas Neumann <a.neumann at carto.net
> <mailto:a.neumann at carto.net>> wrote:
> Hi,
> I am working on the Visual changelog for QGIS 2.10 and I came
> across
> http://changelog.qgis.org/qgis/2.10/entry/allow-changing-vector-layer-data-source/update/
> However, this does not work for me, or I can't figure it out how
> to change a vector data source.
> Also - does it only work for files or also for database sources?
> Could someone please explain how this works?
> Thanks,
> Andreas
> PS: could someone please accept my entries so that they appear in
> the public list?
> Qgis-developer mailing list
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150624/afbc5908/attachment-0001.html>
