[Qgis-developer] LayerBoard plugin - edit project layers properties while drinking coffea !
kimaidou kimaidou at gmail.com
Wed Jun 24 09:45:31 PDT 2015
Hi all,
I am excited to announce the new version 0.5 of my LayerBoard plugin I
started during Nodebo Developper Meeting. It is still experimental but
begins to have the features I was alway looking for when dealing with
complex projects.
Please test it and report issues, or propose Pull requests ! Any feedback
welcome !
Here is the copy of the README file visible in the github repository [1]
------------------------------8<-------------------------------
This plugin helps to see and modify properties for vector and raster layers.
It shows the layers in a table sheet, and the user can directly modify some
properties such as layer name, title, abstract, minimum and maximum scales.
To do so, double-click on a cell and modify the value. The modified cells
are then drawn in yellow, and you can apply or discard the changes via the
button under the table.
Some properties can be changed on multiple layers at once, such as
modifying spatial reference system and scale based visibility. To do so,
select one or more layers in the vector or raster table, and use the right
panel tools in the "Actions on Layers" tab, such as CRS or Max Scale, the
click on the corresponding "Set" button.
Some actions can be performed on multiple layers at once:
   - create a spatial index ( done only on vector layers)
   - save current style as default : it creates a QML file beside the
   source file
The information visible in the "Vector layers" or "Raster layers" tabs can
be exported to a "Comma Separated Values" (CSV) text file via the button in
the tab "Export" of the right panel
When only one layers is selected, the tab "Layer style" in the right panel
displays the current layers style, and you can change the style directly
for the selected layer via the "Apply" button. This is only available for
vector layers.
IMPORTANT : the changes are made in the current project, and will be saved
only if you save the project.
Kimaidou (Michaƫl Douchin)
[1] https://github.com/3liz/QgisLayerBoardPlugin/#layer-board-plugin
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150624/f8b7312f/attachment.html>
