[Qgis-developer] Extended QWC
Uros Preloznik uros00 at gmail.com
Thu Jun 25 00:43:20 PDT 2015
Thanks for trying it out. About StreetView it's true that on first click
panel is not fully resized, but when you continue working with it, it's OK.
So I think not so annoying, but will definitely have to take a look.
I plan to publish GitHub repository with all the code and setup
instructions and welcoming other users to contribute to the project.
Currently I have some work on cleaning up the code and writing setup
procedure.
About LizMap I plan to take the latest version and make a demo out of same
QGIS project I'm using already. That way users will be able to compare
different clients with same data.
regards,
Uros
2015-06-24 10:16 GMT+02:00 Régis Haubourg <
regis.haubourg at eau-adour-garonne.fr>:
> Hi,
> great work !
> I noticed an issue when changing streetview panel size, street view image
> is
> not redimensionned (under chrome at least).
> Do you redistribute your sources and packages somewhere?
> I aw you plan to work on Lizmap later, can you tell us a bit more?
> Cheers
> Régis
> http://osgeo-org.1560.x6.nabble.com/Extended-QWC-tp5211110p5212615.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150625/f89d8dcf/attachment.html>
