[Qgis-developer] Legend filter not working in composer if map layer are locked using a preset
Alexandre Neto senhor.neto at gmail.com
Fri Jun 26 09:55:37 PDT 2015
Can someone confirm that Legend filter (composer) is not working if you use
presets to lock the layers in composer. It simply filters all layers, like
if no features are represented on the map.
The same does not seem to happen if one simply lock the layers from current
map canvas state.
This is happening in master 492c6d9
<https://github.com/qgis/QGIS/commit/492c6d9>,windows 7 64 bits
Thanks.
Alexandre Neto
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150626/f0b3b6d0/attachment-0001.html>
