[Qgis-developer] Using TravisCI integration in Github for QGIS Python plugin
Akbar Gumbira
akbargumbira at gmail.com
Mon Jun 29 09:02:18 PDT 2015
You can also use iface object provided by Python wrapper from qgis.utils.
So in get_qgis_app instead of having the mock QgisInterface, you can do
something like:
from qgis.utils import iface
IFACE = iface
I think in InaSAFE, we don't want unnecessary implementations from the
iface from qgis.utils. I am not aware of the first history of it though.
Regards
On Sat, Jun 27, 2015 at 5:44 AM, Tom Chadwin <tom.chadwin at nnpa.org.uk>
wrote:
> I suspect I'm not going to get this to work. I hit the problem that my
> plugin
> 's code used iface, which was not recognised. I managed to inject the dummy
> iface replacement created in the qgis_get_app () function mentioned above.
> However, next the code calls:
> ```python
> IFACE.legendInterface().groupLayerRelationship()
> While the dummy iface implements a method legendInterface(), it's just a
> stub. It doesn't even return the right object type, but returns a canvas
> object instead.
> I might be able to expand the dummy iface to add in the extra features
> required to get the right object type returned by that method, but isn't
> this all pointless?
> - the more dummy object I have to build, the less real object I am testing
> - the dummy won't have the session data associated with it, such as the
> project's layers
> An I misunderstanding something, or is my attempt to set up testing for
> qgis2web doomed?
> http://osgeo-org.1560.x6.nabble.com/Using-TravisCI-integration-in-Github-for-QGIS-Python-plugin-tp5207646p5213199.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
*Akbar Gumbira*
*Software Engineer*
*Geospatial, NLP, Data Mining, Machine Learning, Artificial Intelligence*
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150630/937d313f/attachment.html>
