[Qgis-developer] 2.10 segfaults on startup
Even Rouault
even.rouault at spatialys.com
Tue Jun 30 04:50:45 PDT 2015
Le mardi 30 juin 2015 13:40:33, Radim Blazek a écrit :
> On Tue, Jun 30, 2015 at 1:22 PM, Even Rouault
> <even.rouault at spatialys.com> wrote:
> > Le mardi 30 juin 2015 13:17:50, Paolo Cavallini a écrit :
> >> Il 30/06/2015 11:15, Richard Duivenvoorde ha scritto:
> >> > Yep, confirmed here on a fresh Debian self compiled version.
> > Might be related to the issue discussed at
> > http://lists.osgeo.org/pipermail/gdal-dev/2015-May/041796.html
> > and
> > http://lists.osgeo.org/pipermail/qgis-developer/2015-May/037820.html
> Thanks Even,
> we can probably get around this using mutex in QgsGdalLayerItem if
> Spatialite is < 4.2.
> Can we get somehow SPATIALITE_412_OR_LATER or bSpatialiteGlobalLoaded
> from GDAL API or its headers ?
Radim,
I can't think a way of getting those internal details from the outside.
However if the (external) spatialite version available when compiling QGIS is
< 4.2, then it is very likely that the one used when compiling GDAL is also <
4.2
The configure test used by GDAL is:
AC_CHECK_LIB(spatialite,spatialite_target_cpu,SPATIALITE_412_OR_LATER=yes,SPATIALITE_412_OR_LATER=no)
You could also fallback to runtime checks with SELECT spatialite_version()
This assumes a setup where not too odd things happen, i.e. compiling with a
version and updating it between compilation of various software components.
Even
http://www.spatialys.com
