[Qgis-developer] PostGIS edition and foreign key
Bernhard Ströbl
bernhard.stroebl at jena.de
Tue Mar 3 03:10:34 PST 2015
the question is how you define your foreign key [1], namely what you put
for "ON DELETE" (you have either NO ACTION or RESTRICT, which throw the
error you receive) If you set ON DELETE CASCADE the operation would be
deleted, too, probably not what you want. Maybe you should set ON DELETE
SET NULL (make sure that the field can be NULL!). Afterwards you
reconnect the operation and the new parcel.
Bernhard
[1]
http://www.postgresql.org/docs/current/static/ddl-constraints.html#DDL-CONSTRAINTS-FK
Am 03.03.2015 11:14, schrieb Thibaut Gheysen:
> Hi,
> I would like to have your opinion in order to simplify as much as
> possible our current workflow.
> We have a table parcel and a table operation. The table operation
> include a foreign key to the table parcel. We have 2 parcels (A and B)
> but only parcel A has operations link on it. I would like to merge the 2
> parcels by keeping the attributes of the parcel A. The merge is doing
> properly but impossible to save the edit (Provider errors: PostGIS error
> while deleting feature: ERROR: update or delete table "parcel" violates
> foreign key constraint"fk_parcel" on table "operation"). I guess this is
> due to the fact the Qgis first delete the 2 parcels (A and B) before
> creating a new one (merged one).
> This behaviour oblige us to export the table parcel into a shapefile and
> make the modifications on it. Once done, we import the shapefile into
> PostGIS and update the parcel geometry base on it.
> Is there any chance to find an easier workflow, without developing a
> plug-in ?
> Thank for your help.
> Best regards,
> Thibaut.
> Qgis-developer mailing list
> __________ Information from ESET Mail Security, version of virus signature database 11260 (20150303) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
http://www.eset.com
