[Qgis-developer] [Qgis-user] accessing a web page from within a plug-in
Rémi Cura
remi.cura at gmail.com
Tue Mar 3 06:38:52 PST 2015
Thank you very much.
It seems that strangely enough,
using `QWebView` automatically takes into account the qgis proxy settings.
For the check of connection, it was actually a lot more complicated that we
thought.
The complexity comes from the fact that all QT web querry are asynchronous.
We put a state machine to switch between local and online version when
there is/there is no connexion.
Many thanks for your help.
Cheers,
Rémi-C
2015-03-02 18:46 GMT+01:00 Enrico Ferreguti <enricofer at gmail.com>:
> http://stackoverflow.com/questions/23041066/setting-proxy-parameter-in-qgis-plugins-how-to
> The only problem is the url exclusions is not implemented in qt class.
> Regards
> Enrico ferreguti
> Da: Rémi Cura <remi.cura at gmail.com>
> Inviato: 02/03/2015 18:20
> A: qgis-developer <qgis-developer at lists.osgeo.org>;
> qgis-user at lists.osgeo.org
> Oggetto: [Qgis-user] accessing a web page from within a plug-in
> Hey dear Qgis list,
> my question is related to network and plugin.
> From within our plugin <http://remi-c.github.io/interactive_map_tracking/>
> we would like to display a User Guide
> <https://github.com/Remi-C/interactive_map_tracking/wiki/%5BUser%5D-User-Guide-%28simplified%29>
> This guide already exists on GitHub, and it would be good to directly
> display the html fo the github page in the plugin.
> Of course internet is not always accessible, so we have a local version of
> html pages in the plugin directory.
> SO there is 2 questions :
> - Are we sure that using the `QWebView` to connect to internet will
> include the QGIS proxy settings? (what is the best practice here?)
> - How to check if it is possible to access an internet page, so that if it
> is not possible to get the online version, we could fall back on the local
> version?
> Thanks for your time ,
> Cheers,
> Rémi-C
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150303/e36b3d7b/attachment.html>
