[Qgis-developer] Fwd: Re: qgis_2.8.1-1~exp1_amd64.changes REJECTED
    Paolo Cavallini
    cavallini at faunalia.it
    Tue Mar  3 23:42:32 PST 2015
Hi all.
Shouldn't we adopt this change upstream?
All the best.
--------  Messaggio Inoltrato --------
Oggetto: Re: qgis_2.8.1-1~exp1_amd64.changes REJECTED
Data: Tue, 03 Mar 2015 19:28:20 +0100
Mittente: Sebastiaan Couwenberg <sebastic at xs4all.nl>
A: Thorsten Alteholz <ftpmaster at ftp-master.debian.org>, Debian GIS
Project <pkg-grass-devel at lists.alioth.debian.org>
Hi Thorsten,
On 02/28/2015 10:47 PM, Sebastiaan Couwenberg wrote:
> On 02/28/2015 07:36 PM, Sebastiaan Couwenberg wrote:
>> On 02/28/2015 05:00 PM, Thorsten Alteholz wrote:
>>>> Unfortunately you can not mix GPLv2 and GPLv3 software.
>> Excluding the dxf2shp_converter plugin in a repacked upstream tarball is
>> probably the best short term solution on the Debian side. This should
>> allow the combined work to fall under the GPL-3+.
> I've uploaded a new revision of qgis 2.8.1 with a repacked upstream
> tarball from which the dxf2shp converter plugin is excluded.
>>>> License: ElvenSword says:
>>>>  * Do not Rip/Merge with other artists work. Example: All in one
>>>>    gradients by Merger/Ripper Nickname) for download/sell
>>>> This is non-free and aren't you doing this with all the other stuff in
>>>> resources/cpt-city-qgis-min/*?
>>>> So I am afraid, there needs to be a new revision of this software.
>> The cpt-city gradients collection included in QGIS states in its
>> README.txt that copyright belong to the respective gradient authors.
>> Since the cpt-city collection doesn't claim to be by a different author,
>> the "Do not Rip/Merge with other artists work." clause doesn't seem
>> applicable. The example describes a collection of gradients claiming to
>> be by a different author than the ones included.
>> Do you think this an acceptable interpretation of the ElvenSword license
>> terms?
> Is this OK, or shall I also exclude the es gradient from the upstream
> tarball?
I've uploaded another revision from which the ElvenSword gradients are
excluded too.
Kind Regards,
Bas
 GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
Pkg-grass-devel mailing list
Pkg-grass-devel at lists.alioth.debian.org
http://lists.alioth.debian.org/cgi-bin/mailman/listinfo/pkg-grass-devel
