[Qgis-developer] american fuzzy lop
Even Rouault
even.rouault at spatialys.com
Fri Mar 6 02:13:57 PST 2015
Le vendredi 06 mars 2015 10:44:48, Hugo Mercier a écrit :
> Hi,
> Interesting.
> The idea of fuzzing is to add random noise to inputs of a program in
> order to make it crash and exhibit hard-to-test branches of code.
> It is very well suited for programs that parse complex inputs.
> For QGIS, the "inputs" are either project files or external data
> sources, where it relies on third party libraries and where the inputs
> are not always easy to represent as files (how to fuzz a postgis database
> So this may be interesting for testing project file parsing.
For XML, you need dedicated fuzzing tool. afl (as far as I know) is more
dedicated to binary fuzzing, which make 99.99999% of what it produces invalid
XML that will be rejected by the XML decoding library before it reaches the
application level.
> But I think it would be better suited for external libraries like GDAL.
Indeed, I've used it a bit recently in GDAL, mainly on the GTiff driver and it
did finds things. Note that afl needs generally to run for several minutes/hours
to be able to find things (unless the code is particularly not robust in which
case a few seconds will be enough to trigger bugs)
> Anyway, automatic tools are always good to try if they can improve the
> overall quality.
> Speaking about tests for external sources, it would be good to add (or
> complete) unit tests for "direct" providers (spatialite, postgis, etc.),
> probably as an option, since the setup is platform-dependent.
> Le 06/03/2015 07:55, Paolo Cavallini a écrit :
> > It promises to find bugs and help fixing them.
> > Il 06 marzo 2015 07:53:57 CET, Nathan Woodrow <madmanwoo at gmail.com> ha
> > scritto:
> > What does that even do?
> > On Fri, 6 Mar 2015 at 16:52 Paolo Cavallini <cavallini at faunalia.it
> > <mailto:cavallini at faunalia.it>> wrote:
> > Hi all.
> > Anybody knows about this?
> > http://lcamtuf.coredump.cx/afl/
> > Would it make sense to try and include it in our tests?
> > All the best.
> Qgis-developer mailing list
http://www.spatialys.com
