[Qgis-developer] Issue #5606 - defining column data types
Matthias Kuhn matthias at opengis.ch
Mon Mar 9 02:48:13 PDT 2015
Hi Karolina,
Do you already have an osgeo account?
If no, you need one.
When logged in, you can click "Update" at the bottom of the issue page
and there's an option "Assigned To".
If this does not appear for you (not sure, may be due to permissions),
just drop a message here and somebody can do it for you. Or write an
answer on the issue, that is probably enough already.
Thank you very much for tackling this anyway. If you have further
questions, don't hesitate to ask.
All the best
Matthias
On 03/09/2015 10:39 AM, Caroline Alexiou wrote:
> Hello,
> My name is Karolina and would like to work on
> issue http://hub.qgis.org/issues/5606
> We deal with long numbers at work that are in fact 64 bits, and the
> default behaviour casts them to floats when working with csvs, losing
> some precision. I am motivated to add an option to force the data type
> of fields when loading a layer as delimited text, but I am not sure
> how I can claim the issue on hub.qgis.org <http://hub.qgis.org>.
> Thanks
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150309/03ab1518/attachment.html>
