[Qgis-developer] Post-processing queries on postgis layers (after insert/delete/update)
Jürgen E. Fischer
jef at norbit.de
Tue Mar 17 12:07:03 PDT 2015
Hi Olivier,
On Tue, 17. Mar 2015 at 18:08:18 +0100, Olivier Dalang wrote:
> I'm able to run SQL queries after inserts using this signal :
> QgsVectorLayer.committedFeaturesAdded(layerId, addedFeatures)
> The problem is that the addedFeatures array contains the features in their
> state BEFORE they were committed.
Are you sure it is? I didn't try, but the postgres provider already updates
the feature ids of the features passed to QgsPostgresProvider::addFeatures and
and emits those in committedFeaturesAdded afterwards when the commit is run.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150317/77ab105d/attachment.pgp>
