[Qgis-developer] Qgis-developer] Make error - QGIS Latest (2.6.0) and QGIS 2.8.1 too
Mark Wynter
mark at dimensionaledge.com
Sun Mar 22 14:04:41 PDT 2015
Hi Jerome
You will need to compile Qgis against Python 2.7 - which you need to install from source. Not yum.
You then need to make sure you have the latest bindings installed.
add the KDE repo - it has many of the required libs in there.
This is my QGIS setup
QGIS version 2.8.1-Wien QGIS code revision exported
Compiled against Qt 4.8.5 Running against Qt 4.8.5
Compiled against GDAL/OGR 1.11.1 Running against GDAL/OGR 1.11.1
Compiled against GEOS 3.4.2-CAPI-1.8.2 Running against GEOS 3.4.2-CAPI-1.8.2 r3921
PostgreSQL Client Version 9.3.5 SpatiaLite Version 2.4.0
QWT Version 6.0.1 PROJ.4 Version 480
QScintilla2 Version 2.8.4
> Hi,
> I manage to compile without error 2.8.1 on Centos 6.5 with python
> 2.6.6.
> Please see my notes here :
> http://gis.stackexchange.com/questions/139693/half-solved-compilation-of-qgis-2-8-against-grass-7-from-source-with-centos6-5
> (also repeated later below)
> But at the runtime, I have the same error like Mark Wynter, described
> in
> http://lists.osgeo.org/pipermail/qgis-developer/2014-November/035397.html
> a pop-up with "Couldn't load plugin 'processing'
> Traceback (most recent call last):
> File "/usr/local/share/qgis/python/qgis/utils.py", line 185, in
> loadPlugin
