[Qgis-developer] Using QGIS for parallel processing
Patricia Carbajales pcarbaj at clemson.edu
Sun Mar 22 14:15:32 PDT 2015
Hi Mark,
Thank you for your response. Very helpful.
Also, the resources you mentioned are fantastic. Very well written and extremely useful.
Thank you!
Patricia
-----Original Message-----
From: Mark Wynter [mailto:mark at dimensionaledge.com]
Sent: Saturday, March 21, 2015 6:05 PM
To: qgis-developer at lists.osgeo.org
Cc: Patricia Carbajales; georger.silva at gmail.com
Subject: Re: Using QGIS for parallel processing
hi Patricia - links to a couple of articles that might spur your thinking.
http://dimensionaledge.com/intro-vector-tiling-map-reduce-postgis/
http://dimensionaledge.com/from-days-to-minutes-geoprocessing-of-alberta-land-use-data/
As George mentioned, Qgis is brilliant for multithreaded rendering - particularly when installed on your multi core processing servers and accessed by Remote Desktop (RDP) which minimizes the amount of data that has to traverse your broadband link in order to visualize it.
But when it comes to the multi core geoprocessing itself, there's a wide range of tools equipped for the job. The code patterns I've shared above are on github and are PostGIS focussed - but they can be easily adapted to incorporate R, GRASS, GDAL commands and more into a single parallel pipeline job. Scripting skills are a must.
HTH
mark
