[Qgis-developer] wrong attribute values for postgis data in Feature attribute form
    Régis Haubourg
    regis.haubourg at eau-adour-garonne.fr
    Thu Mar 26 02:34:50 PDT 2015
Hi, I have seen such troubles when the choosen primary key from qgis side is
not unique .
Symptoms: selecting one feature select severals unrelated features of the
same layer. relation with attributes is broken also.
Can you check in your layer's definition (general tab of layer properties)
if you choose gid field as key, and check if it is really unique in postgis?
Cheers
Régis
View this message in context: http://osgeo-org.1560.x6.nabble.com/wrong-attribute-values-for-postgis-data-in-Feature-attribute-form-tp5195518p5195523.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
