[Qgis-developer] wrong attribute values for postgis data in Feature attribute form
Bernhard Ströbl bernhard.stroebl at jena.de
Thu Mar 26 03:07:33 PDT 2015
Hi Raymond,
Am 26.03.2015 10:57, schrieb Raymond Nijssen:
> Thanks Regis, that was exactly the issue. The (boolean!) field
> 'inonderzoek' was used as a key. When I change that to 'gid' in the Add
> PostGIS Table dialog, everything works correctly.
> Can anyone tell me why QGIS picks that boolean field for most of my
> tables? Can I change that behaviour by changing my database structure?
Maybe I can, but I would need the table definition statement for it. Can
you post it here.
Generally speaking you should define an integer field (use bigint if you
expect _many_ datasets) as primary key for the table like:
CREATE TABLE my_points
   gid integer NOT NULL,
   the_geom geometry(Point,my_srid),
   other_fields,
   CONSTRAINT my_points_pkey PRIMARY KEY (gid)
Bernhard
> http://terglobo.nl/downloads/qgis_add_postgis_table_wrong_key.png
> And how can the identify results be correct anyway?
> Tnx,
> Raymond
> dbname='bag' host=localhost port=5432 user='postgres' sslmode=disable
> key='inonderzoek' estimatedmetadata=true srid=28992 type=POLYGON
> table="bagactueel"."pandactueelbestaand" (geovlak) sql=
> On 26-03-15 10:34, Régis Haubourg wrote:
>> Hi, I have seen such troubles when the choosen primary key from qgis
>> side is
>> not unique .
>> Symptoms: selecting one feature select severals unrelated features of the
>> same layer. relation with attributes is broken also.
>> Can you check in your layer's definition (general tab of layer
>> properties)
>> if you choose gid field as key, and check if it is really unique in
>> postgis?
>> Cheers
>> Régis
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/wrong-attribute-values-for-postgis-data-in-Feature-attribute-form-tp5195518p5195523.html
>> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
__________ Information from ESET Mail Security, version of virus signature database 11379 (20150326) __________
The message was checked by ESET Mail Security.
http://www.eset.com
