[Qgis-developer] [Print Composer] Attribute table item. Relation option is missing
Nyall Dawson
nyall.dawson at gmail.com
Sun Mar 29 01:15:06 PDT 2015
On 29 March 2015 at 19:10, Alexandre Neto <senhor.neto at gmail.com> wrote:
> Thanks Nyall.
> I have also noticed that the appearance menu is not showing for older
> projects already with a table item in a composer.
> I will try to make a few more tests.
Yes, that's expected. When the attribute table was upgraded to handle
frames it required an API break. To avoid issues with scripts which
relied on composer templates I had to make the call that the old style
tables would not be upgraded automatically to the newer tables. That's
why older projects won't see the newer table features.
Just delete and re add the tables and you'll see all the new options.
Nyall
> Em 28/03/2015 23:12, "Nyall Dawson" <nyall.dawson at gmail.com> escreveu:
>> On 29 Mar 2015 9:40 am, "Alexandre Neto" <senhor.neto at gmail.com> wrote:
>> > Hello all,
>> > While doing screenshots for the User Manual, I have noticed (actually it
>> > was Larissa) that In Print Composer I can't see the relation option of the
>> > attribute table item.
>> > I'm using QGIS 2.8.1 in ubuntu 14.04.
>> > Please see the first images of this commit to see what I mean:
>> > https://github.com/qgis/QGIS-Documentation/commit/cacb92d13de8adda26709ff1dbff48494600f31c
>> > Can anyone confirm this? Is there any condition in a project so that the
>> > relation option show up?
>> You'll need:
>> - a project with relations
>> - an atlas with the coverage layer set to the parent layer from a relation
>> Nyall
>> > Best regards,
>> > Alexandre Neto
>> > _______________________________________________
>> > Qgis-developer mailing list
>> > Qgis-developer at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
