[Qgis-developer] Update datumTransformEntries on layerCrsChanged ?
René-Luc Dhont rldhont at gmail.com
Tue Mar 31 01:53:14 PDT 2015
Hi Dev,
One of our customer discovered a bug in the couple QGIS / QGIS-Server.
He discovered that the element layer_coordinate_transform_info, child of
mapcanvas element, was not updated after a layer CRS changed and project
saved. This causes some troubles in QGIS-Server, because it uses this
element to defined CRS transformation.
I proposed a Pull-Request https://github.com/qgis/QGIS/pull/1971
If my proposed patch is accepted, I propose to backport it to 2.8 for a
2.8.2 version.
Thanks for review.
Regards,
René-Luc
