[Qgis-developer] Re : [Qgis-user] Pyqt4 : which signal is sent when dialog comes to foreground?
Junior Delaz delazj at gmail.com
Tue Mar 31 05:04:37 PDT 2015
Matthias,
Thanks. I just give it a try it and all goes well with composerAdded.
But not really well with composerWillBeRemoved signal. The first deletion
in the composer manager does nothing and deleting a second composer does
remove the first one in my list. and so on...
My update function should be rewritten I think.  I'll try to see how
improving it and may (surely) ask again for help (if needed).
While seeking information about composerWillBeRemoved, I found a
composerRemoved [1] [2] signal (that doesn't appear in the API doc) and
without being able to use it. :(
[1]
https://github.com/qgis/QGIS/blob/master/src/app/composer/qgscomposermanager.cpp
(line 48
[2] https://github.com/qgis/QGIS/blob/master/src/app/qgisapp.cpp (line 5601)
Another thing that may not be related : what the deletePrintComposers
function (https://github.com/qgis/QGIS/blob/master/src/app/qgisapp.cpp line
5698) is for?
Thanks again for the clue.
2015-03-31 9:43 GMT+02:00 Matthias Kuhn <matthias at opengis.ch>:
>  QgisInterface (iface) has a composerAdded and composerWillBeRemoved
> signal.
> Did you try to connect to these?
> Best,
> Matthias
> On 03/31/2015 09:34 AM, Junior wrote:
>  Hi all, Luca
> Thanks for answering. But i already have an update function that I linked
> to an update list button. I even linked it to the icon on the toolbar so
> that when user calls foreground the dialog it's already updated.
> The case I'd like to manage: user can open plugin dialog and composer
> manager. The two dialogs are visible (to the eyes) even though composer
> manager is the one at foreground. He makes changes and directly clicked on
> the plugin dialog. He should update list but if he forgets and executes,
> this may lead to bug I don't want to / can't yet manage.
> Reason why I want to ensure that list is always up to date when he
> interacts with the dialog
>  Envoyé depuis mon HTC
> ----- Reply message -----
> De : "Luca Manganelli" <luca76 at gmail.com> <luca76 at gmail.com>
> Pour :
> Cc : "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
> <qgis-user at lists.osgeo.org> <qgis-user at lists.osgeo.org>, "qgis-developer"
> <qgis-developer at lists.osgeo.org> <qgis-developer at lists.osgeo.org>
> Objet : [Qgis-developer] [Qgis-user] Pyqt4 : which signal is sent when
> Date : mar., mars 31, 2015 07:56
> On Mon, Mar 30, 2015 at 6:12 PM, Junior Delaz <delazj at gmail.com> <delazj at gmail.com> wrote:
> > I've read about defining a custom showEvent function but can't understand
> > where to put it and what inside.
> > If somebody can give some tips...
> You could add a "Update list" button
> Qgis-developer mailing listQgis-developer at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150331/383b933f/attachment.html>
