[Qgis-developer] Broken compile 2.9
J.O. Williams j.o.williams.jow at gmail.com
Fri May 1 20:59:02 PDT 2015
I did a "git pull" against the latest git repository and had it fail for
the build.  I am running "14.10 (Utopic Unicorn)".
I hit the following error:
[ 81%] Building CXX object
src/plugins/grass/6/CMakeFiles/grassplugin6.dir/__/qgsgrasstools.cpp.o
/opt/src/QGIS/src/plugins/grass/qgsgrasstools.cpp: In constructor
‘QgsGrassTools::QgsGrassTools(QgisInterface*, QWidget*, const char*,
Qt::WindowFlags)’:
/opt/src/QGIS/src/plugins/grass/qgsgrasstools.cpp:60:17: error: no
matching function for call to ‘QgsGrassTools::setupUi(QgsGrassTools*)’
    setupUi( this );
/opt/src/QGIS/src/plugins/grass/qgsgrasstools.cpp:60:17: note: candidate is:
In file included from /opt/src/QGIS/src/plugins/grass/qgsgrasstools.h:21:0,
                  from /opt/src/QGIS/src/plugins/grass/qgsgrasstools.cpp:17:
/opt/src/QGIS/build-master/src/plugins/grass/ui_qgsgrasstoolsbase.h:52:10:
note: void Ui_QgsGrassToolsBase::setupUi(QDialog*)
      void setupUi(QDialog *QgsGrassToolsBase)
note:   no known conversion for argument 1 from ‘QgsGrassTools*’ to
‘QDialog*’
src/plugins/grass/6/CMakeFiles/grassplugin6.dir/build.make:387: recipe
for target
'src/plugins/grass/6/CMakeFiles/grassplugin6.dir/__/qgsgrasstools.cpp.o'
failed
make[2]: ***
[src/plugins/grass/6/CMakeFiles/grassplugin6.dir/__/qgsgrasstools.cpp.o]
Error 1
CMakeFiles/Makefile2:3442: recipe for target
'src/plugins/grass/6/CMakeFiles/grassplugin6.dir/all' failed
make[1]: *** [src/plugins/grass/6/CMakeFiles/grassplugin6.dir/all] Error 2
Makefile:146: recipe for target 'all' failed
make: *** [all] Error 2
I previously had built the Makefile using "ccmake ..".  Shouldn't ccmake
catch a version problem or missing library?
I got a running qgis by "make -i" and "make -i install" and it finished
normally.  I didn't hit the missing modules while I used it today.
My current build from help->about is:
QGIS version    2.9.0-Master    QGIS code revision    e12601e
Compiled against Qt    4.8.6    Running against Qt    4.8.6
Compiled against GDAL/OGR    1.10.1    Running against GDAL/OGR 1.10.1
Compiled against GEOS    3.4.2-CAPI-1.8.2    Running against GEOS
3.4.2-CAPI-1.8.2 r3921
PostgreSQL Client Version    9.4.1    SpatiaLite Version    4.1.1
QWT Version    6.0.0-svn    PROJ.4 Version    480
QScintilla2 Version    2.8.3
Is it OK to do a build using "make -j 4" (or -j whatever) to utilize the
multiple cpu cores during a make?  (I have but is there a hidden gotcha)?
Thanks for your time.
J.O. Williams
